03-15-2006, 4:41 PM
Does anybody use earplugs for wakeboarding? I got smashed my eardum a year ago, and I thought it would be a good idea to use them just in case. Does somebody knows if this is dangerous? Speedo Earplug
03-15-2006, 5:14 PM
Oscar, I use these for everything. http://www.proplugs.com/ I have a pretty good case or "surfers ear" and once the water is in it doesn't want to come out. I have used that style of ear plugs in the past but the Docs are way more comfortable. Board More/Work Less! Wadd$
03-15-2006, 5:19 PM
I got swimmers ear last summer and it was the most horrible pain i have ever been in.
03-15-2006, 5:24 PM
Use them all the time when boat riding. Busted an eardrum once, don't need that sensation again. Its actually peaceful to not hear anything when I ride.
03-15-2006, 5:28 PM
I busted a eardrum once. Used plugs for a while. Friend of mine busted his three times. Your local ENT doc can make a "custom" set for you. Molded for your ears.
03-15-2006, 5:40 PM
Busted mine before also. Silly putty works wonders and sealed better than anything I tried!
03-15-2006, 5:49 PM
Doesn't a helmet help?
03-15-2006, 5:54 PM
I use the proplugs also. They are vented so they allow sound in without letting in the water. I recommend them. You don't want a busted eardrum or have surgery for swimmers/surfers ear.
03-15-2006, 5:57 PM
I've done mine twice. not always Dane. When the pressure of the water hits your helmet, that flap over your ear delivers the same pressure surge you get from the water. The water doesn't have to enter your ear to damage the membrain. I watched it happen at wakeboard camp to a guy wearing a surfing helmet. Same idea as cupping your hand over your ear.
03-15-2006, 7:45 PM
I use the pictured plugs and they work great (from CVS $4 a pair). I just cut off about a half inch of the part sticking out of the ear so they are not so conspicuous.
03-16-2006, 7:32 AM
I started wearing my helmut last year and found it really helps to keep the water out
03-16-2006, 8:21 AM
Over the last 2 years I have busted both eardrums. During the healing process, while riding, I used the wax type of ear plugs. I tell everyone to ride once with ear plugs. What a cool sensation. On a warm day with decent water, try to ride without your sense of hearing. Maybe it was just me...but the sence of peace and serenity.....very different.
03-16-2006, 9:05 AM
Went riding the other day in cold water and was the only one that experienced massive pain in my ears. Was told it was simply from the cold water. It went away completely after about 1/2 hour. Never had this problem before. Do I have swimmers ear? Thinking of wearing those ear plugs too.
03-16-2006, 10:01 AM
I was actually thinking of tryig out the Liquid Tunes for both eardrum protection and some beats while riding. Billy has blown his eardrums a couple times and ended up riding most of the year last year with ear plugs.
03-16-2006, 11:40 AM
Evan If you ride behind J-rods boat why do you need the liquid tunes? The nvs are not loud enough?
03-16-2006, 1:20 PM
Someone was talking about the Top American Emergency Room visits for Sports injuries. One of the (I think he said) top 3 injuries for wakeboarding were surgical removal of ear plugs. I think he said Concussions were number one, with Lacerations number two.
03-16-2006, 1:24 PM
Interesting.... At least with the liquid tunes you could just pull them back out by the cords. LOL. Eric: behind his boat you need the earphones to knock the volume down to less than deafning levels.
03-16-2006, 2:21 PM
I would go with the plugs that fill up your outer ear aswell like the pro-plugs. I've heard of quite a few occasions of the small ear plugs being pushed through the ear drum, I wouldn't think it would be that easy but apparently it happens.
03-16-2006, 2:58 PM
It seems that the physical chances of that happening are slim, I could be wrong though. There is not much surface area on an earplug for water to push hard enough to force through the inner ear during a fall. You have a much much greater chance of blowing your eardrum w/o the plugs.
03-16-2006, 8:38 PM
cosmocat...I use them all the time with no problem. I also cut off the excess tip so they don't stick out of the ear canal. Rob kc...I agree...it's nice not hearing anything but your own breathing out there
03-16-2006, 10:19 PM
trust me I thought it was odd the first time I heard it too. the way you blow out an ear drum is having a pocket of air trapped in your ear when you slap the water or descend to quickly, so in theary the plug through the ear is highly unlikely, but I keep hearing about it.
03-17-2006, 6:46 AM
If surgical removal of ear-plugs made a top 10 list on Emergency Room Wakeboard related injuries...It must be happening. I wish who ever had access to that info would chime in here..
03-17-2006, 12:55 PM
wasnt there a dude who actually did a study on that? Ages ago, he was researching injuries of wakeboarders. But all the cases I've heard about the plug through the ear drum, none of them are wakeboarders, mostly boaters/sailors.
