Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 15, 2006
Old     (gandr_nautique)      Join Date: Feb 2006       03-02-2006, 3:04 AM Reply
I have a SN 1994 with a PCM engine and was looking at getting Perfect pass. I need to now if it is fuel injected? As far as i now it is the smaller 290 HP engine.
Old     (superairdawg)      Join Date: May 2003       03-02-2006, 4:07 AM Reply
I don't recall the first year PCM introduced throttle-body injection, but even if your engine is carb'd, you can still install Perfect Pass and it will work just fine.
Old     (peter_c)      Join Date: Sep 2001       03-02-2006, 8:07 AM Reply
Is it a Boss or Pro Boss engine? Boss (285 hp)is carbed and Pro Boss is fuel injected. Even better just look under the flame arrestor and see if there is a carb. You do not even need to take it or the plastic cover off to see.
Old     (jayc)      Join Date: Sep 2002       03-02-2006, 8:10 AM Reply
Hope you not fitting it yourself. If you don't know if you boats inj or carb'd then drilling a 2" hole in the bottom might be fun!
I know the 93 was carb'd.
Old     (gandr_nautique)      Join Date: Feb 2006       03-02-2006, 8:34 AM Reply
Fitted one last week no problems so dont worry about any holes. Thanks for the help i was pretty sure it was a carburetted 285 PCM so all good now. Cheers
Rob
Old     (superairdawg)      Join Date: May 2003       03-02-2006, 8:37 AM Reply
Actually, the Pro Boss wasn't necessarily fuel injected. I had a '94 Sport with the Pro Boss engine and it was carb'd. In '94 CC started offering ProTec Fuel Injection as an option.
http://www.correctcraftfan.com/reference/1994_brochure/index.asp?page=05
Old     (peter_c)      Join Date: Sep 2001       03-02-2006, 9:24 AM Reply
Joe, you are 100% correct and I am wrong. Doh! I was thinking GT40. The Pro Boss was the Waste Spark upgrade, yet still carbed, that is the 285 HP.
