Isaac, If it is an OEM tower from the factory or it was a custom tower attached with a fixed tower foot then you can run it trough the tower foot to hide the wires (some OEM towers have hime joints or universal fittings though and you will have to exit the wires out of the pipe and into the deck). You will mostlikly have to jump the wires around any hinge fittings though. To aid in chasing wire I found that useing fishing line with a small piece of plastic bag tied onto the end of it. And then suck like hell from one hole to another (use shop vac). Then you can pull your chase wire with that (steel mig wire works great for a chase wire). Make sure you deburr the inside and outside of the holes you drill in the tubeing before you start chasin. P.s. Those speak-on conectors loog great Chris, it gives the install a finished look!
