Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 23, 2005
Old     (zacky)      Join Date: Apr 2003       07-08-2005, 5:56 PM Reply
My buddy has an '02 X-30 and we were thinking about doing a little alteration to the decals. I was wondering, how easy would it be to cut the red portion out of the center of the sticker (sorry, no pictures) and just leave the X30 and the circle design around it. I am assuming a sharp razor blade and a light touch would get the job done. What should I expect once the sticker comes off?
Old     (jklein)      Join Date: May 2001       07-11-2005, 3:55 PM Reply
If you do that, you will most likely scratch the underlying gel coat with the razor blade causing expensive damage to the boat. There may be some gel coat fading too.
A better solution is to purchase new stickers, cut out the parts you don't want when they're off the boat, and replace the ones on the boat with the new ones you just bought.
Old    robertt            07-11-2005, 7:22 PM Reply
Why dont you try tracing it out first, getting some vinyl from a local sign maker in the color you want, then cutting it yourself and putting it over the existing color. While it will be true that there will be a slight bump around it, it will not be any worse than the stock decal.
If you really like it, you can have a sign maker do the entire thing custom to your liking.
I wouldn't take a razor blade to mine though.
Tracing paper will be less than five bucks, get a large sheet from office depot used for tracing blueprints.
A large sheet of colored vinyl should be under twenty bucks, and the entire thing is easily removable.
Just a thought.
Old     (bigredhusker)      Join Date: Jan 2005       07-11-2005, 8:28 PM Reply
try this link
http://www.wakesiderides.com/viewArticle.php?id=146
