Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 15, 2005
Old     (braddo)      Join Date: Feb 2005       02-21-2005, 12:37 PM Reply
hey i have a air 206 2001 model and im trying to wire a ballast pump of the keyless ignition keypad does anybody know where these wires are and what colours am i looking for
Old     (tigeal)      Join Date: Jul 2002       02-21-2005, 2:13 PM Reply
Did not know there was a Air 206 in 2001?
2001 year Air Nautique would have came with ballast system standard. If it is a 2001 sport and does not have factory ballast then you will find a wiring loom bundled up under the dash or behind the driver kick panel. These wires will have connectors on the ends with end caps plugged in, everything is wired and ready to go just connect to your pumps and your set. In that bundle will also be wires for factory optional shower but I believe they are seperate. The pump wire loom will have four connectors and two pair will be shorter wire than the other two, shorter two are for the fill pumps and the longer two will be the drain pumps. As for the wire colors go to planetnautique site and use there wire diagrams for the air series, not really important though as it will be obvious when you find them and as mentioned the wire length will indicate fill or drain pumps.
Old     (braddo)      Join Date: Feb 2005       02-21-2005, 2:26 PM Reply
sweet ill see how i go
