Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2004
Old     (hyperlitenrd)      Join Date: Jan 2003       08-02-2004, 8:31 PM Reply
Ok I have a 04 LF team 139 with xxl 04 parks, and the screw on the inside on my left foot keeps comming loose, like after 20 min it has to be re tightened, it had to be retightened 4 times on saturday, this is after loosing the whole claw last saturday. I know the bindings have the smaller screws for LF boards, Im wondering if im missing something.
Old     (pittsy)      Join Date: Apr 2004       08-02-2004, 9:18 PM Reply
buy LF board with LF bindings or HL board with HL bindings...problem fixed..
Old     (512boarder)      Join Date: Jul 2004       08-02-2004, 9:35 PM Reply
try some loctite. you would probably want to use red tho so that you can unscrew the screw again when u want. but for sure locktite will solve your problem.
Old     (kristian)      Join Date: Nov 2002       08-02-2004, 11:47 PM Reply
The screws on Hyperlite bindings are longer than the inserts on LF boards, put an extra washer underneath the head should fix it. Or go down to home depot and get some shorter screws.
Old     (scott_a)      Join Date: Dec 2002       08-03-2004, 12:46 AM Reply
if i were you i would go to the hardware store and buy some screws that are 1/4 inch shorter than the ones that the HL claw comes with.
Old     (jarrod)      Join Date: May 2003       08-03-2004, 6:49 AM Reply
I used extra washers like Kristian suggested. Problem solved.
Old     (hyperlitenrd)      Join Date: Jan 2003       08-03-2004, 6:46 PM Reply
The guys at cope and mc phters gave me shorter screws so i thought that ment i wouldnt have a problem, but i do, ill try putting washers on. and its only the inside of my left foot (which is my front foot) does that happen often where only one comes off?
Old     (kristian)      Join Date: Nov 2002       08-04-2004, 12:16 AM Reply
Well if they allready gave you shorter screws and they don't bottom out, then loctite would be your solution there.
Old     (guido)      Join Date: Jul 2002       08-04-2004, 1:17 PM Reply
Beer can tabs under between the screws and the claw. That should have been the oficial ~DMC~ answer, right guys?
It actually works too. We figured this out on a houseboat trip in desperation.
