Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 06, 2004
Old     (denwakebdr)      Join Date: Apr 2004       06-29-2004, 11:00 PM Reply
Installed a new deck.....The old deck was a sony 35x4 the new deck is Kenwood....50x4...The problem is anytime it pulls too much power..or I trim the outdrive it shuts down...started doing this while the boat was off and by turning the volume up past 24....any suggestions or ideas...please help
Old     (bigdad)      Join Date: Apr 2002       06-30-2004, 8:38 PM Reply
Um ok. But what is up with the title of this thread?
Check your connections. Does the power wire have a good connection. Try running a direct line to the battery. If the power wire is attached to the same power wire to the outdrive then it could be draining the power.
