Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 07, 2004
Old    1dega            05-10-2004, 2:58 PM Reply
Who sells lead ballast anymore.I tried the lead headz link but it did not work.Anyone know of some good deals on lead?
Old     (wakestar8878)      Join Date: Oct 2003       05-10-2004, 3:01 PM Reply
Yeah I've been looking for lead also. Even our "friends," that use it won't tell us where they got it. WTF?
Old     (dcervenka)      Join Date: Sep 2002       05-10-2004, 3:04 PM Reply
Go to an indoor shooting range, pick up some lead, and then throw it in some sacks.... it's cheap.
Old    huckleberry            05-10-2004, 3:11 PM Reply
Also try going to a tire repair store. Ask if they have any old tire balancing weights they are going to be getting rid of. That's were we get our lead for fishing weight.
Old     (wakestar8878)      Join Date: Oct 2003       05-10-2004, 3:15 PM Reply
Thanks for the info. What I'm really looking for is some 40 to 50 lbs sheets.
Old    1dega            05-10-2004, 3:29 PM Reply
I need at least 300 to 400lbs.There has to be someone making ballast lead bricks.
Old     (dcervenka)      Join Date: Sep 2002       05-10-2004, 3:35 PM Reply
You will pay anywhere from $.70 to 1 per pound for lead bricks.
Drop off a few buckets at the indoor range and you can probably get it for FREE.
Here are some links that might help your search.
http://www.wakeworld.com/MB/Discus/messages/65921/66088.html?1052395056
http://www.wakeworld.com/MB/Discus/messages/65921/105908.html?1080790526
Old     (thane_dogg)      Join Date: Jun 2002       05-10-2004, 3:35 PM Reply
no way!! Try POP Products. It's approximately 40 lbs of steel shot that comes from the waste of a steel machining shop. The shot is in a sealed plastic bag which is then placed inside another vinyl bag with handles. They freakin' rock.
I guess you can only get them in SoCal, shipping them would be a task.
T-Roy WHER ARE YOU?!
Old    cam_warner            05-10-2004, 4:04 PM Reply
Go to a tire shop or an indoor shooting range, and they'll give you lead for cheap if not free. Then, if you're so inclined, melt the lead down into bricks, and you can make them whatever size you want. Then just coat them in that rubberize-it coating, and you've got your own lead-hedz for about 1/10th of the price.
Old     (wakestar8878)      Join Date: Oct 2003       05-10-2004, 4:11 PM Reply
Ok, for all the SoCal peeps,
I found Industrial Metal Supply in Irvine. They have 65lbs. ingits (spelling?). They measure 18 to 20" long, by about 3" wide for $55.90 a piece. Their phone # is (949) 250-3343
Old     (thor)      Join Date: Oct 2001       05-10-2004, 4:20 PM Reply
Proflight is selling 65 lb lead bars for $65/bar. They told me if I bought at least 10 bars they would drop the price to $55/bar.
After thinking about it for about 2 seconds, I decided my fat sacs work just fine, and I don't have to drag around the extra weight.
Old     (troyl)      Join Date: Feb 2002       05-10-2004, 4:30 PM Reply
Cal Correct Craft sells the Pop Products 40lb weight bags for $29 and they won't damage the boat, are easy to unload from the truck and you can't stub your toe on them.
Old     (socalwakepunk)      Join Date: Dec 2002       05-10-2004, 5:06 PM Reply
Get the Pop Products bags! They are way better than any bar or brick!
Old     (dcervenka)      Join Date: Sep 2002       05-10-2004, 5:45 PM Reply
Does POP have a web site?
Old     (troyl)      Join Date: Feb 2002       05-10-2004, 6:03 PM Reply
Web site coming soon. Impossible product to sell direct with freight costs.
e mail me for dealer listing for your area
tlindstrom@lynamindustries.com
Old     (mvl)      Join Date: May 2004       05-10-2004, 7:17 PM Reply
dude, just do as a couple others and myself have done, go to a tire repair shop, I went to a ford dealership and get tire weights. I've got a couple 2.5 gallon buckets with tops for like $3 at that hardware store, fill'em with the weights, then use water to fill in the rest adding another couple lbs, and maybe sand for more, cap it!
Hunters who reload shot-gun shells buy bags of lead shot that weight 25lbs/bag. My neighbor gives me the bags filled back up with the spent primers. Doesn't weight much/bag, but I've got literally 500+lbs of easily moveable weight for the cost of a few buckets. Get smart, gas isn't cheap!
Old    damnation            05-11-2004, 6:00 AM Reply
I bought some 4" PVC and some end caps. Then I did what a lot of other people here have done and got some tire balancing weights from service stations (they were happy to get rid of it). Cut the PVC to desired length and put one end cap on using plumbers dope. Then fill the PVC with the weights and cap the other end. This process works perfectly b/c you can make them any size you want and they fit perfectly under the seats. They are also easy to move around.
Old     (kirk)      Join Date: May 2003       05-11-2004, 7:34 AM Reply
1. Shooting range lead.
2. Plastic "Jerry Cans"(They have handles already attached)
3. Pour the loose lead shot into the cans ...
No melting required, Cheap, no mess, easy to make and move around in the boat.
I have 4- 5 gallon cans in my boat. Total cost was less than $75.
Anyone know what the weight of a gallon of lead is?
Old     (jonb)      Join Date: Oct 2003       05-11-2004, 8:10 AM Reply
water is better to use but more of a hassle, with the lead you have to tow the boat with all of that extra weight.
Old    damnation            05-11-2004, 8:50 AM Reply
1 gallon = 0.1336806 cubic feet
The density of lead is 705 lbm/cubic foot.
Therefore, 1 gallon of lead should weigh 94.24 lbm, neglecting air volume of course. However, this is assuming that the metal is pure lead, which is probably not the case. So, I would say anywhere from 75 lbm to 90 lbm.
Old    norcal_99            05-11-2004, 9:17 AM Reply
My friend Randy told me he got some 80lb bags of cement at Home Depot for $3.00 each. Soaked them in water so they'd harden while still in the bag. Then he put three on each side of his engine and three up front under the seats in the bow. It added a lot of weight to his boat and it barely takes up any of the storage room.
I've also heard of people using sand, but I would think sand might make a mess if the bag tears open. At least cement is solid.
Old    beerdrnknboardr            05-11-2004, 4:30 PM Reply
the melted down lead that you get from tire shops works good and can be put outta the way easier, but if you just want some weight get a good six 5gal buckets of cement and then to hold them in place get some cheap 50-100lb bags of bird feed. The bird seeds will get messed up when wet though
Old     (mdan)      Join Date: Apr 2003       05-11-2004, 7:07 PM Reply
go to your local donut shop, duncan donuts, krispy kreme on a early sunday morning etc. You can ask the first two people in line to come out for a nice ride in a nice wakeboard boat.....instant heavy ballast, cheap, easily moves around, and will probably supply the donuts also.
Old     (shakes5)      Join Date: Mar 2003       05-11-2004, 9:55 PM Reply
VERY FUNNY....
