Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 17, 2004
Old     (hamkj)      Join Date: Apr 2002       02-10-2004, 1:14 PM Reply
If the factory does not install a transom remote... I was just wondering if there are any tips when cutting holes into fibreglass/gelcoat... to avoid spider cracking and flaking etc...
I put pop up cleats in my old boat and you could see some minor cracks in the gel coat...
Can you avoid this?
Old    g3revenge            02-10-2004, 1:21 PM Reply
start with a small drill bit and work your way up.
drill slow. (don't build up any heat)
tape off the area to avoid chips.
don't over tighten your mounting screws/bolts to avoid cracks.
Old     (noneya)      Join Date: Apr 2002       02-10-2004, 1:36 PM Reply
tape off the area, run the drill in reverse, chamfer edges of the hole
Old     (wakehound)      Join Date: Oct 2003       02-10-2004, 2:51 PM Reply
I'll second taping off and running the drill in reverse. Even doing both of these steps though, you might still get some cracks. Good luck!
Old     (jklein)      Join Date: May 2001       02-10-2004, 3:58 PM Reply
I would also use a new bit. Tape over the area with masking tape.
Old     (prostar205v)      Join Date: Aug 2002       02-10-2004, 4:22 PM Reply
tape area, use hole saw drill and reverse speed. Go very slowly. I did this to the back of my boat and had no problems with cracking. If I remember correctly 1" 7/8 or 2" hole saw did the trick. Mine was for a circle clarion.
(Message edited by prostar205v on February 10, 2004)
Old     (whazzup)      Join Date: Oct 2001       02-10-2004, 6:43 PM Reply
You should also countersink the hole to prevent spider cracks.
Old     (hamkj)      Join Date: Apr 2002       02-10-2004, 9:19 PM Reply
Thanks for the tips... I contacted the factory with my request... so as long as their stereo supplier will get them a Sony Y-adapter for the LCD remote... they will install one in the transom for me!
