Alright so heres the problem....
2004 Tige 24v Limited, only 150 hours on the boat. Last weekend we started having issues. Pretty sure its the 5.7 engine.
-First got in the water ( still on trailer) the engine fired up immediately but when I put it in reverse the engine died. It then would not crank over again for about 2 minutes and after it set for about 1 minute it turned on fine and we were able to play the rest of the day with no issues. Sometimes when it goes into gear from Neutral I can hear some knocking/clicking noise for a few seconds but then it goes away.
-Just got back from the lake today and we had an even worse issue. The boat had a little trouble turning on and warming up when we put it in the water, but we were able to get out on the lake and surf for probably 4 hours. I noticed that we didn't really have as much power as usual, could only get up to around 28mph ( not running ballast at this time). At the end of the day and with no ballast, we were only able to get up to around 15mph and the boat was working hard to get on plane with the throttle all the way down. We used to get up to around 35mph top speed so something is definitely wrong.
I am thinking a few things, a fuel issue, fuel filter/pump, distributor issues or possibly spark plugs?? It would be nice to know where I should start looking.
