Old     (Brandin10)      Join Date: Jul 2015       07-24-2015, 7:29 PM Reply
Hi All.
Went out surfing today. My friend and I are getting good enough now to lose the rope. But I am doing much better than he is. My question is would the weight of the surfer make a difference in how well the wave pushes?? Would a heavier surfer require a bigger wake? He is 205lbs and I'm 185lbs. We're both riding the same board. He thinks that it's easier for me because I'm lighter??
Thank you
Old     (flee27)      Join Date: Jul 2015       07-25-2015, 6:16 AM Reply
I am definitley not an expert but yes it does matter. The board also matters a lot, probably more than the wave. A good wave is a good wave and you both should be able to surf it. If the board he is using is not big enough/buoyant enough the it would take a wave with a lot more "push" for him to surf ropeless.
What board are you using? There is a pretty big weight spread between you two. Probably will not be able to effectively use the same board.
Foster
Old     (markj)      Join Date: Apr 2005       07-25-2015, 7:46 AM Reply
My own weight has fluctuated between 185 and 205 over the last few years and I can tell you weight does make a big difference in how easy it is to stay in the pocket.
Old     (Brandin10)      Join Date: Jul 2015       07-25-2015, 9:11 AM Reply
Awesome thanks guys. Looks like it's time to go board shopping
