Old     (Brandin10)      Join Date: Jul 2015       07-23-2015, 11:02 AM Reply
All
I am new to surfing and have been reading a lot of posts on boat set-up. Can someone please explain the term "Listed" to me.
Thanks In Advance
Old     (iShredSAN)      Join Date: Apr 2012       07-23-2015, 11:29 AM Reply
http://culture.evo.com/2013/06/setti...aughan-part-2/
Old     (all2matt)      Join Date: Apr 2015       07-23-2015, 11:43 AM Reply
being leaned over. boats that run listed (non surf system) run between 7 degrees all the way upto and maybe beyond 18 degrees. My tige Z1 I ran at about 10 degrees, i liked it steep to get tons of push pumping down it plus it was fun for lip tricks beinga ble to do a slight ollie onto the lip and back down (like wakeboarding to me).
the other way is drifted (surfgate, NSS, etc.....) thses boats drive at a slight angle allowing the off/other side water to not come in contact with the surf side water til its past the riding portion of the wake.
listing is done by weighing your surf side rear 100% front 25-50% and offside rear 25-50% giving you that slight lean.
drifting makes for an easier boat to setup but listing makes for a better (IMO) riding wake.
Old     (sidekicknicholas)      Join Date: Mar 2007       07-23-2015, 11:45 AM Reply
This boat is listed
Old     (all2matt)      Join Date: Apr 2015       07-23-2015, 11:53 AM Reply
just dont list this far :-)
Old     (Brandin10)      Join Date: Jul 2015       07-23-2015, 1:09 PM Reply
Ok. Thanks. That's what I figured the term was referring too.
Old     (Brandin10)      Join Date: Jul 2015       07-23-2015, 1:10 PM Reply
great link. Thank You
Old     (Brandin10)      Join Date: Jul 2015       07-23-2015, 1:24 PM Reply
Old     (Brandin10)      Join Date: Jul 2015       07-25-2015, 12:03 PM Reply
So this is my configuration
500lbs hard tank on surf side
550lbs plug n play bag full on surf side
800lbs ronix eight.3 bag full on rear surf side seat
I think I need a little more in the front?
Should I fill the opposite side at all or leave that side empty??
Old     (Brandin10)      Join Date: Jul 2015       07-25-2015, 12:05 PM Reply
Another note. My boat weighted and just sitting in the water has about 3" before the water level hits the rub rail
Old     (v10rider)      Join Date: Oct 2012       07-26-2015, 1:05 PM Reply
Every boat is different. You will need to play around with the weight up front and counter weight. Rule of thumb is weight up front will lengthen the wave and gives the wave a better transition. Counter weight OTOH, depends on the boat.
Old     (Brandin10)      Join Date: Jul 2015       07-26-2015, 2:25 PM Reply
Thanks v10rider. Gonna try another sack up front next time out to see if we can make it a little longer!
