Old    atx_shred            07-01-2014, 9:16 PM Reply
do you think that 134 to a 140 would be a crazy jump? I'm probably a 135 if I were to get a board to my exact size but will a 140 be a real challenge or will it be hard to notice too big of a difference? it may be easier to press?
Old     (chrislandy)      Join Date: Mar 2014       07-02-2014, 3:00 AM Reply
I've just gone from a 135 watson to a 142 (that I built) and the difference was night and day at the cable, much more stable and soft as butter landings. (180lb and 5'8") I'm building a 137 to try and see which one works best but I'll most likely use the 137 on the boat and 142 at the cable
Old     (skiboarder)      Join Date: Oct 2006       07-02-2014, 6:12 AM Reply
It is about 2.5 inches. Odds are, if you are moving from a 134 to a 140 your stance will widen about a hole, There is two inches. That means that you are only adding about a .25 inch to your tip and tail. In short, It is not really that big of a deal unless you are really small. <150 lbs and 5-6.
Old     (cwb4me)      Join Date: Apr 2010       07-02-2014, 6:17 AM Reply
I'm 5'6" and weigh 168 lbs. I ride 3 different boards a 139,141 and a 142 . Bigger is better for soft landings, but i've never noticed the weight difference.
