Originally Posted by 07vlx
I have an Alpine CDA-9886M head unit and the older version WS420. At the end of the season last year when I would link to another boat through the boat link on the 420 my head unit subwoofer eq would automatically drop to -4. After adjusting the eq on the head unit back to flat the volume of my stereo would be cut in half even with the volume all the way up. I suspect the problem is in the head unit but wanted to hear from the experts what you think and if there is a way to test which one the culprit could be or both.
While anything is possible, if something is changing inside the HU then that would appear to be independent of the EQ.
A common thread could be low voltage. The HU is loaded with microprocessors and they get wiggy with low voltage.
So I would make sure that the HU and EQ share a good gauge + supply and a good gauge - ground that are terminated at the same points, which would be at or near the primary terminals of the amplifiers.
Then I would have a multimeter handy to check the voltage at the HU and EQ terminals (not at the battery or dash meter) real time if the problem occurs again.
Exhausted batteries have a habit of showing up with voltage issues at the end of the day toward the end of the season. If you are playing the system at rest for a long duration then you MUST supplement your boat's charging system with AC shore charging.
