Chris,
Are you sure that you need 5 RCA cables? How many amps do you have? Many multi-channel amps will allow the signal to be passed through to all channels with only a single set of RCAs connected to the amp. If you do need to split the RCAs, then adding a in line driver of some kind will allow you to split the cables without a noticeable loss of signal quality.
