Originally Posted by joeshmoe
OK, thank you, looks like I am ready to roll, well as soon as the rain stops.
Here is the Info from the Indmar Owner's Maunal regarding that light
If the engine is equipped with the Walters V-Drive transmission,
there may also be a Check Transmission light. If
low oil pressure is sensed in the V-Drive, the light will go
on indicating the problem. Under normal operation, the
light will stay lit at idle and slow speed operation until
enough pressure is produced (1200 RPM ± 400 RPM).
Extended cruising or trolling at low RPM is not harmful,
even if the light is lit, provided that the V-Drive oil level is
sufficient. If the oil level is normal and the light stays lit
above 2000 RPM, take the boat to your Indmar dealer
for service.
