09-12-2009, 10:06 AM
I use spray wax every time out of the lake, but hear a bunch about a 50/50 mix of vinegar. Does this just take the spots off or does it leave a shine? Do you use it when you trailer it home and your spots are dried on, or right when you pull it out of the water?
09-12-2009, 10:34 AM
gets rid of water spots but it also strips wax. I used it for a long time then switched to hot sauce.
09-12-2009, 10:48 AM
I use the Vinegar mixture only for removing stubborn waterspots. Be sure to follow up with mild soap and H2O and then rewax as the vinegar strips the wax.
09-12-2009, 11:58 AM
Vinegar is a mild acid. Water spots are calcium and other dissolved minerals in the water. The acid in the vinegar eats the minerals so them come off easily. Think like a really mild CLR. You can use it at any time but it gives no shine.
09-12-2009, 1:47 PM
1/3 vinegar, 1/3 water, 1/3 babes everytime. Perfect.
09-12-2009, 1:57 PM
8:1 vinegar to Turtle Wax Zip Wax.
09-12-2009, 2:07 PM
Seems weird that vinegar and wax would work well together.
09-12-2009, 2:19 PM
Karl, last time I tried to mix Turtle Zip Wax and vinegar, I couldn't get the wax and vinegar to mix properly. It was like the wax coagulated.
09-12-2009, 2:35 PM
I don't think that vinegar strips wax. I mix vinegar, water, and soap in my spray bottle, it’s cheap and it works. Mixing wax and water or vinegar doesn't make any sense, they won't ever mix.
09-12-2009, 3:47 PM
I love Hot sauce but I Have a black boat and if its hot enough even Hot sauce won't take off the water spots, I've never tried vinegar but I think I might give it a try.
09-13-2009, 7:42 PM
Water, vinegar & Turtle Wax. Still not completely sure of the mix yet, but something like 25% vinegar, 25% wax & 50% water. Got it from a WW member & have been using it for a couple of months with good results. (Message edited by bill_airjunky on September 13, 2009)
09-14-2009, 6:30 AM
30% vinegar 70% water at the ramp side clean up. It leaves the hull and windows perfectly clean. I have not found it to take off wax.
09-14-2009, 7:35 AM
Deez, Wax your boat with a quality wax and a buffer. Use Babe's when you pull the boat out. You won't have any problems with water spots. The key is the wax!
09-14-2009, 8:07 AM
If you're on the water all day, and have some spray on your boat, you'll still get some spots, especially if you have a dark colored boat. I normally just use Wax as You Dry on my boat, everytime we pull out, but if I have stubborn spots, I'll use my 50/50 mix of vinegar and distilled water on areas that have bad spots. Once the spots are gone, follow it up with the Wax as you Dry on a damp rag and it's slippery again!
09-14-2009, 3:56 PM
If you have a really strong vinegar, you dilute a bit. I have used up to 40% Zip Wax in vinegar. The acid will repel the wax a bit. You need to shake it up frequently. The main point is to have a bit of soap and wax to cut through the scum and crud that all water seems to leave behind.
09-14-2009, 4:27 PM
I'm surprised no one's mentioned this one yet. I was a vinegar & water user, but began to get concerned about wax stripping. Saw a few threads about the "Driven" product, and I bought some. LOVE IT! Recommended to friends and now they like it too. It's economical since it comes in a concentrate). Great for spots and leaves surface very glassy smooth (far superior to V/W mixes).
09-15-2009, 8:12 PM
I use hot sauce and love it -black boat. Grew up using 50:50 W:V and noticed it does take a little shine off the wax (definitely not a full wax strip), but always works great. One thing I have been wanting to try is Zip Wax w/vinegar -I don't see how this can work without a full boat wash after you use it, The Zip Wax needs to be washed off with water after application....
