Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 24, 2009
Old     (99_air_warrior)      Join Date: May 2008       08-24-2009, 7:32 PM Reply
How Much ballast can you put in a 99 air warrior elite ? I have asked the question before without an answer I also tried the centurion crew. no response someone must weight down a Centurion Air warrior Thank You Joe
Old     (hawkeye7708)      Join Date: Feb 2007       08-24-2009, 7:36 PM Reply
Rule of thumb I was told was that MAXIMUM capacity of a boat is 2X the posted weight limit on that little panel thing.
Old     (99_air_warrior)      Join Date: May 2008       08-24-2009, 7:46 PM Reply
Has anyone sack one out ? and how did you do it ? Thank You Joe
Old     (okcwakebrdr)      Join Date: Dec 2004       08-25-2009, 7:46 AM Reply
Sack it down till it wont plane out! Then pump out till it does. That should be the most weight you can put in it. Just go by the old rule 40% front, 60% rear.
