For new seats you can contact Correct Craft.. They can hook you up to something good. It's also an idea to drive to your local refurnisher (if I spell it correct) and do something you like... About the weight. We put pretty much weight in front... About 400lbs in the nose and 2x250 at the side of the engine.. Our wake is clean, steap and BIG... I compared it to some other new boats (pro Air, Tige) and found our bigger and steaper and harder... The only drawback is that the wake is only clean above 21mph at 65f... So for wakeskating it's not that perfect.. Tommy
