Old    Eubanks (eubanks01)      Join Date: Jun 2001       05-20-2009, 11:53 AM Reply
The carpet in my Malibu is peeling off the hull in a couple of spots in my storage areas. What type of glue do you all use to reattach the carpet to the hull? Thanks.
Old    TigeMike (chpthril)      Join Date: Oct 2007       05-20-2009, 12:20 PM Reply
3M Trim Adhesive spray.
Old    Eubanks (eubanks01)      Join Date: Jun 2001       05-20-2009, 12:44 PM Reply
Can you just get this at Walmart or where? Thanks Mike.
Old    John Bauer (jonyb)      Join Date: Nov 2008       05-20-2009, 12:58 PM Reply
Sometimes the spray glue's aren't strong enough or thick enough to hold the heavy backed carpet in these boats. I still haven't found anything that will hold. If it's not on the side of the boat or in the gunwhales you may try staples.
Old    TigeMike (chpthril)      Join Date: Oct 2007       05-20-2009, 12:58 PM Reply
Pretty common at most any auto parts store.
Old    Razzman (razzman)      Join Date: Dec 2006       05-20-2009, 12:59 PM Reply
I've used waterproof contact cement from Home Depot, works great and holds great even on walls and such. Use a mini roller to apply it.
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       05-20-2009, 2:21 PM Reply
Spray glue in boat....come on?
Do this...scrape of the old excess glue and clean the area with a minieral spirit. Got get some contact cement from home depot and a throw away paint brush. Apply contact cement to both sides and let it get tacky for about 4 minutes. Stick and down and you will be good to go.
Old    Joe Curtis (jcurtis)      Join Date: Mar 2007       05-20-2009, 2:38 PM Reply
i used a hot glue gun last year and seemed to work fine
Old    pete c (saceone)      Join Date: Jan 2009       05-20-2009, 10:55 PM Reply
contact cement is the way to go. the waterproof one
Old    George Aslinger (mobv)      Join Date: Jun 2002       05-20-2009, 11:29 PM Reply
I used 3M Trim Adhesive and it works.
