Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 03, 2009
Old     (eviltweak)      Join Date: Jun 2008       05-06-2009, 8:22 AM Reply
What is the best way to build a spool without welding it
Old     (xbones)      Join Date: Mar 2007       05-06-2009, 8:45 AM Reply
Old     (svt600)      Join Date: Sep 2008       05-06-2009, 2:09 PM Reply
+1 to the above! but why not weld it?
Old     (mrboston187)      Join Date: Jul 2008       05-06-2009, 5:40 PM Reply
+2, However I agree with Zimmerman because, we just built a winch, with essentially the EXACT same spool as pictured above, except we used giant grinding plates instead of pizza pans. Anywho, with 600 feet of line, the crosbars are starting to twist and get a little crooked. I would imagine though, that if you had more line, that would greatly ease the pressure on the spool. If I were you, I would build something like the one pictured, but at least tack weld everything in place.
my .02
Old     (svt600)      Join Date: Sep 2008       05-06-2009, 7:41 PM Reply
just go to a place that builds trailers or something like that and ask them to weld it up for you... they should do it do a few bucks... it it will be a lot stronger then just bolting it.....
the bolts will work if that all you can do tho!!
Old     (xbones)      Join Date: Mar 2007       05-07-2009, 6:11 AM Reply
FYI- I did weld this up... but It could have run without IMO.
Old     (eviltweak)      Join Date: Jun 2008       05-07-2009, 9:53 PM Reply
alright is there any was to bore out something to be 1-1/8 inch. preferably a grinding disk.
