![Reply](images/buttons/reply.gif) |
04-25-2009, 11:38 AM
I would like to upgrade my pathetic sound system and the first thing I need to do is improve the low end by replacing the stock Kenwood free-air subwoofer. I don;t have a lot of room in the boat, so the idea of just adding another free-air sub is very appealing to me but I would like to know if it's worth going this route or I should splash on a custom enclosure. I don;t need to entertain the lake but I need good quality sound and enough power to at least entertain the female passengers i my boat every now and then :-) I looked at JL M10IB5CGW and Wet Sounds XS-10FA, but I like the looks of the Wet Sounds a lot more. I will also eventually replace all my boat speakers with wet sounds.
04-25-2009, 12:25 PM
I've installed a few of the XS-10FA's, and they're okay. You won't get much at all out of a free air woofer, but if it's a last resort, then go for it. The XS12 sounds great if it's in the right box and has the right power.
04-25-2009, 1:57 PM
You probably need to consider and amp upgrade also, the sub is only as good as the power going to it. Cant go wrong with the xs10-fa when power right! The xs-10fa sounds great with 400+ w's rms going to it!
04-25-2009, 2:20 PM
I will replace the amp as well, I was thinking about the WetSounds Syn Micro (recommended on their website), but that's nowhere near 400+ W RMS. Can I consider a beefy car amp rather than a marine one? The amp will never be exposed to the elements. Will the kick panel under the driver's seat rattle? Any concerns? What amp do you recommend?
04-25-2009, 2:31 PM
I've done a handful of them powered buy the Class D sub chnl of the Kicker zx700.5 and delivers 420W's when wired at 2ohm's. I have not heard the sub powered with anything less, but I doubt you would be disappointed with the Micro, but it will handle more!
04-25-2009, 3:08 PM
In the 2nd stage of this upgrade process I will replace all 6 in boat speakers with 6 wetsounds XS-650. Will the sub still provide enough bass then? From what I read the XS-650 have decent mid-bass.
04-25-2009, 4:06 PM
If you're gonna replace all the in-boats with 650's, use the Syn6 amp. That'll be 600W on the sub, and 100W per channel on the in-boats.
04-26-2009, 5:00 AM
^^^ X2. If you have room for an enclosure, then step up to the xs-12 with the 600W's!!!
04-26-2009, 6:08 AM
i have installed the micro with the xs-10fa it was ok but not really what your going to want from the sounds of it your wanting a little more. I run the xs10-fa in my boat w 350 watts going to it and it thumps.I think the xs10-fa is a great sub at a great price if you power it right as stated above.I went from a clarion marine 10 to the xs10 with same amp and it was night and day difference.I also run three sets of xs-650.So you will have same set up as me.Im running clarion marine amps but want to step up to the wetsounds amp.I have installed a few of the WS amps since they came out and they are awsome.If you go syn 6 -xs10-fa- 3 sets xs-650 you will be very happy i can assure you. (Message edited by kko13 on April 26, 2009) (Message edited by kko13 on April 26, 2009)
04-27-2009, 10:15 AM
Claudiu, The Supra 21V doesn't have the floor hump under the drivers console so I'm assuming that your factory 10-inch sub is mounted in the carpet-clad HDPE facade. Because its wide open over the top of the panel the sub is not isolated front to rear. So, no matter what free-air sub you use it will be a major disappointment in your application. Without the floor hump you have a great deal of room behind the facade. Definitely get an XS-12 in an enclosure. You could get by with the Syn Micro but 200 watts bridged into 4-ohms might be a bit light for the XS-12. For a more permanent solution, I would start at around 300 watts honest power. There are lots of options in your budget. David Earmark Marine
04-27-2009, 10:24 AM
That's what I'm afraid of with the free-air sub, I'll spend a lot for slightly better results. You're right about the panel, it is wide open at the top. For now I will try to squeeze a sealed-boxed 12" Kicker sub + Kicker amp (400W RMS 2ohm load, from one of my cars) inside the closed compartment of the boat (I don;t know how to call this, it's where both my batteries and all my vests are now), and spend my 2009 budget on upgrading the the 6.5 speakers with wetsounds and a good amp. In 2010 I will deal with the rest. I hope the car amp+sub will be fine this summer.
04-27-2009, 1:50 PM
Claudiu, I'm certain your Kicker 12" will fit in an enclosure under the driver's helm console, thereby preserving your storage in the port locker. David Earmark Marine
04-27-2009, 5:24 PM
I did an install a few weeks ago on an X-Star with an XS-12 in a ported enclosure powered by the sub channel of a Syn6. It sounded great for what it was. Also have an XS-10FA on a Clarion Marine 4-channel.
