Old     (markfromtexas)      Join Date: Apr 2003       04-19-2003, 11:10 PM Reply
I've got a 03 x-30 w/ internal ballast, took it out for the first time after winterization but my tanks wouldn't fill, any suggestions why?
Old     (rodmcinnis)      Join Date: Sep 2002       04-21-2003, 12:46 PM Reply
seacock turned off?
Vent line is shut?
Old    pbob            04-21-2003, 2:11 PM Reply
Do the pumps run? - if not check your fuses.
Old    aircanada            04-21-2003, 3:21 PM Reply
If your 03 is anything like my 02 x-10 I believe the pumps should be on circuit breakers. Reach up under the panel the ballast switches are located on, you should feel three nipples, each one should be almost directly under the switch it corresponds to. Pushing in on the nipples should reset the circuit.
