Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through October 06, 2008
Old     (victory07rdr)      Join Date: Aug 2008       09-20-2008, 5:19 PM Reply
Well, I test drove a MB Sports 190 two weeks ago and all was well, except I found out the bilge doesn't work. I bought the boat last night and took it out today. I didn't even get past the bouys before the temperature buzzer went off. I knew right away what it was. I took it home and sure enough, the impeller is toast. How'd this not come up when I test drove it??? Anybody know where to buy a new impeller? Thanks Guys
Old     (bill_airjunky)      Join Date: Apr 2002       09-20-2008, 5:28 PM Reply
Bummer. If you bought it from a dealer, I'd be chapped that they didn't change it out for you.
It's really a good idea to check the impeller anytime your not sure about it's condition.
Old     (hatepain)      Join Date: Aug 2006       09-20-2008, 5:42 PM Reply
check www.skidim.com they should have one.
Old     (trevorg7)      Join Date: Mar 2008       09-20-2008, 7:14 PM Reply
2nd Skidim and buy two. I always carry a spare on the boat. Change it out on the water if needed and keep going.
T
Old     (rvh3)      Join Date: Jul 2003       09-20-2008, 7:18 PM Reply
This may help....
Skidim Autumn Specials!
Hot Deals Exclusively For Our E-Mail Subscribers
Enter your promotion code word
LAYUP at checkout and get
10% off your entire web order!
Old     (jeff359)      Join Date: Jun 2005       09-20-2008, 7:44 PM Reply
"always buy two"
Spoken like a true veteran. I never thought of it, till it happened to me. I always have one in the glove box.
Old     (stephan)      Join Date: Nov 2002       09-21-2008, 3:24 PM Reply
Yep, always keep a spare on board. It's especially easy to change if it's a direct drive. Some V-drives are a bitch. Also if it comes down to it you can run your fat sac pump into the block, will keep up with enough RPM to idle back to the launch in a real pinch.
Old     (1boarder_kevin)      Join Date: Mar 2007       09-21-2008, 5:39 PM Reply
I change mine every spring no matter what. The last thing I want to think about is an impeller. They only cost $30. The longer they are in, the harder they are to get out.
Old     (burbanized)      Join Date: Mar 2004       09-24-2008, 12:12 PM Reply
I Agree on that one
ALWAYS carry a spare!
Old     (sidekicknicholas)      Join Date: Mar 2007       09-24-2008, 12:22 PM Reply
we always have an extra on the boat too...just in case.
Old     (evil0ne)      Join Date: Sep 2006       09-25-2008, 8:48 AM Reply
Aren't most impeller's under the water line? How do you change on the water? Trust the bilge pump? I've heard of stuffing a rag, just not sure about the pressure that would be coming in.
Old     (flux)      Join Date: Jun 2003       09-25-2008, 8:58 AM Reply
Many boats have a seacock before the impeller on the raw water intake.
I have spare belts and an impeller always.
Old     (greatdane)      Join Date: Feb 2001       09-25-2008, 9:12 AM Reply
I had a used three times impeller break the other day. I took the pump off and impeller looked fine. Next, I turned the pump to see that the impeller was spinning internally within it's self. A damn defective impeller.
Old     (trevorg7)      Join Date: Mar 2008       09-25-2008, 9:22 AM Reply
evilOne - I've changed my impeller on the water with no problem.
'93 Ski Nautique, 351 Ford PCM.
T
Old     (denverd1)      Join Date: May 2004 Location: Tyler       09-25-2008, 9:37 AM Reply
The most important $20 part on the planet.
Old     (bill_airjunky)      Join Date: Apr 2002       09-25-2008, 9:49 AM Reply
Never had a problem changing the impeller on the water on my MC 205. Probably a bit more of a PITA on the Vride, but only because it's all done blind.
I've never heard of a boat taking on water while the impeller is being replaced.
Old     (sidekicknicholas)      Join Date: Mar 2007       09-25-2008, 11:27 AM Reply
when we went to florida we only had one with us and we were suppose to go out for a photo shoot and the impeller went....a nautique dealer was near and from them it was $75....since we needed the boat had no choice, but otherwise gotta love ebay
