Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (hatepain)      Join Date: Aug 2006       08-18-2008, 8:35 AM Reply
When I put it in gear (not neutral) whether forward or reverse its a little grindy for the first 1/4 inch or so. Is the throttle cable going out?
Old     (nasty530)      Join Date: Aug 2007       08-18-2008, 10:47 AM Reply
The cable is prob starting to fray. There will be a stiff outter caseing on it that is mounted to the engine. I should be on top of the motor somewhere, alot of times it will be red or someother bright color. Take a look at the exposed cable and see what it looks like...
Old     (nasty530)      Join Date: Aug 2007       08-18-2008, 10:48 AM Reply
actually, after thinking on it for a sec. If your throttle cable was going out, it would do it reguardless of whether you were in gear or not. So, I would say it is in your throttle/shifter...
