Andy, there are a couple of problem areas on these boat from 2000 to 2001. Look closely at the ignition and accessory keypads as some went bad. Also the LCD gauges were prone to going bad requiring either new $200/each gauges or a retro fitting kit which most people go with. Some other big things to check. Engine Compression, steering cable, cd player, hatch latches for the back compartments... I have an entire check list if you'd like.
