Zirk on the prop? Or on the rudder? Definitely should be on the rudder, under the floor, right where the rudder shaft comes up into the boat. You may also find one under the steering wheel on the rack. Not sure what rack Tige uses but my old MC had one there too. Grease it, then work the wheel back & forth, then try greasing again, work it back & forth, etc.
