Old     (dreamer69)      Join Date: Sep 2006       07-24-2007, 5:16 PM Reply
Does this look like a good starter boat for a beginning wakeboarder http://www.wawaseeboatcompany.com/1989_ski_nautique.htm
thanks
Old     (dkjbama92mariah)      Join Date: Dec 2005       07-24-2007, 5:42 PM Reply
Very pretty boat. How long has it been sitting in the water? You might want to haul it out and check the entire hull for osmotic blistering. Is that fresh or saltwater?
Old     (dreamer69)      Join Date: Sep 2006       07-24-2007, 5:59 PM Reply
Fresh water. We just found it on the net. Going to go look at it this weekend. What are some problem areas to look for? from the picture the interior looks new.
Old     (tuffenuff)      Join Date: Aug 2006       07-24-2007, 6:11 PM Reply
Is that a closed cooling system shown? If it is, it's a plus. Find out what tranny and prop are on the boat. Look for cracks in the gel also
Old     (ck73)      Join Date: May 2006       07-24-2007, 6:19 PM Reply
That’s a sweet old boat my buddy just got one just like that(nice wake) if you can pick it up for under 8k your doing good regardless of the condition.
Old     (bremsen)      Join Date: Aug 2005       07-24-2007, 6:49 PM Reply
http://www.planetnautique.com/CorrectCraftManuals/2001.htm
Very good boat, known for its excellent wakeboard wake. Doesn't look closed cooled to me (thats a muffler, stock on 89s). The bowls on the holley are leaking (or maybe were), but other than that it looks very clean, complete, bone stock 89. Nice find.
also check out www.the2001.com for more info.
Old     (dreamer69)      Join Date: Sep 2006       07-24-2007, 6:55 PM Reply
Are all 82-89 Correct Crafts 2001's?
Old     (bremsen)      Join Date: Aug 2005       07-24-2007, 7:39 PM Reply
No, CC made several model boats in that time period...the 2001 is just the most sought after hull/boat by wakeboarders. You can also check out www.correctcraftfan.com, there is a ton of old reference material available online.
Good luck in your search.
Old     (westsiderippa)      Join Date: Dec 2006       07-24-2007, 10:16 PM Reply
Buy it !!!!!!!!! Slam it!!!!!!!!!!!! then post some pics of the wake and you doing a hochie into the next county.
Old     (malibuboarder75)      Join Date: Jan 2004       07-24-2007, 10:29 PM Reply
Scott, that isn't closed cooling. It is the muffler they used in 1989
Old     (tuffenuff)      Join Date: Aug 2006       07-26-2007, 8:57 AM Reply
My bad. My '88 MC has closed cooling and the resevoir looks similar, but positioned on side of motor. Clean CC!
Old     (charman)      Join Date: Aug 2006       07-26-2007, 9:09 AM Reply
looks good. what are they asking?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-26-2007, 9:27 AM Reply
she's clean, that for sure. red valve covers... what was it, Boss engine in the 90's nautiques? looks like a 351 tho.
At first glance, the engine is too clean to have 700 orig hours. But, the interior is immaculate too. just ask a few questions, they both could be redone.
Old     (shredhead)      Join Date: Jun 2003       07-26-2007, 9:49 AM Reply
I have an 89, great boat. Really the best of the 2001 series. That's the standard 240HP engine, yes it may have had or has a cracked bowl in the carb. Fairly common, but easy fix.
Check the floor for soft spots! Take a wrench and turn the bolts under the engine hatch, make sure they are not stripped.
Drive the boat, that was the first year of the 1.23 transmition, check the fluid and listen for a whine.
