Like Peter said, it is probably the paddle wheel. Crawl under the boat while it is on the trailer, look at all the things poking through the hull. Identify and ignore the ones that are water intakes (probably brass). There will be one that is probably black plastic, an outer flanch about three inches in diameter with a inner diameter of about 1" or so. Inside this inner diameter should be a little paddle wheel. The lower tips of the paddle hang down and get turned by the water flowing by. Reach up and see if you can turn the paddle wheel. If it won't turn freely then figure out what is jamming it. It is not unusual for some tiny critter to decide to makes its home there. It is also possible that the paddle wheel is missing, which means it got broken off at some point. They can be replace without too much effort. Note that the inner portion of the paddle wheen assembly can be removed from inside the boat. I believe that you need to remove it in order to replace the paddle wheel. Rod
