Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old     (jwharan)      Join Date: Nov 2006       03-29-2007, 3:53 PM Reply
Can someone explain to me the process for running speaker wire on a titan III tower? The dealer wants like 250 to do this, which seems very excessive to me.
Old     (sbt3)      Join Date: Jun 2002       03-30-2007, 6:27 AM Reply
You need to drill a hole in the tower in the bottom where you want the wires to come out. It needs to be above the weld where the cone meets the tubing. The cone is solid so don't drill into it. Drill a hole on the top where you want the speaker wire to come out. Take a piece of small string or rope and feed it into the top hole at the same time hold the hose from a vacuum to the bottom hole which will pull the string into it. Tie the speaker wire to the string and pull it from the bottom to the top with the string you just pulled through. Put in some grommets to keep the wire from getting cut and your done.
Note- I assume the Titan 3 is the same as the series 1's that I have done. I am not 100% sure on this but I would think they are.
(Message edited by sbt3 on March 30, 2007)
