03-27-2007, 10:36 AM
What kind of jack does everyone keep with them in the event they have a flat tire on the trailer? I have a Supra 24 SSV and it is fairly heavy. I have used the jack from my Toyota Tundra on my last boat, but I do not think it is heavy enough.
03-27-2007, 10:45 AM
I just bought one like this because it was cheap ($25) and very lightweight. Boat is in storage so I don't know if it fits my trailer yet. http://www.amazon.com/dp/B000BGM4WK/ref=nosim/?tag=nextag-sg-20&creative=380333&creativeASIN=B000BGM4WK&linkCod e=asn
03-27-2007, 11:04 AM
If the one that comes with your vehicle fits under one side of the axle it will work. There is some margin of error built into vehicle jacks. Just make sure nothing is going to roll, and the lift is straight. Funny how many people carry a spare for their boat, but do not have a jack that will work, nor a lug wrench that fits. Jack the axle up. Remove the wheel. Tie axle to frame. Lower jack and drive to your destination, on three wheels.
03-27-2007, 12:24 PM
Carry a 4X6 block of wood with a 60 degree bevel (ramp) cut in one end (I usually tow with my rv so I have some wood with me). Drive trailer up onto block using the good tire and leave the flat tire hanging. Must have a lug wrench and spare if not check peter c's post above. Also this assumed you have at least a two axle trailer.
03-27-2007, 12:51 PM
I got a cheapie scissor jack from Walmart, my F250 jack won't go under the axle. This is a good post, everyone should check to see if their tow vehicle jack can actually get under the axle of their boat trailer. Peter also brings up a good point about tying the axle to the frame. If you ever blow a hub or bearing, you will need to remove the rim and tie the axle to the frame and limp it home. Maybe a heavy duty strap, strap clamp, or piece of chain just in case. Have heard of folks carrying an extra hub with bearings just in case.
03-27-2007, 2:30 PM
I got a flat and since I hadn't test my jack, it didn't work because it wasn't tall enough. Luckily, I found a big rock and drove the good tire up on it. Since then, I screwed together three 2x6's on top of each other and staggered them to sort of form a ramp. This time I tested it on my driveway and it works great. Just drive the good wheel up on it and you're golden. Gramps gave me the idea.
03-27-2007, 2:43 PM
Yeah, what the hedoublehockeysticks is up with proving an OEM jack that won't get the gall dern vehicle high enough off the ground? My stock jack would get the truck up high enough to get the flat tire off, but not the inflated tire back on. That's just effin wrong. I now carry a floor jack and jack stands in my bed box.
03-27-2007, 3:39 PM
providing
03-27-2007, 4:14 PM
i actually keep a big floor jack in my explorer now. since i use the vehicle for nothing other towing the boat its really not an inconvience to keep in in there. and is makes life MUCH easier.
03-27-2007, 4:17 PM
I was towing my boat behind a u-haul from California to Texas. I blew out a tire in Freakin Gallup, New Mexico. (Getting my Kicks on Route 66). Well I had a jack from a 93 Silverado. Worthless P.O.S.( The Jack). I unhitched the boat and drove to Wal-Mart and bought a 3-1/2 ton floor jack for $60. I will take it with me on long trips from now on. http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200303997_200303997
03-27-2007, 4:24 PM
I carry a floor jack,star wrench,plug kit and compressor.
03-27-2007, 4:36 PM
Check your tire stems regularly. On boat trailers they tend to get dry rot very quickly. When they fail, it can cause a blow out even if the tires are fine. Very dangerous, but very easy to prevent. Also, Peter C is right, check your tire iron to be sure it fits the lug nuts on your trailer. Often the tow vehicle and the trailer have different sized nuts. (Message edited by lakeski on March 27, 2007)
03-27-2007, 4:43 PM
Sorry, I didn't mean to answer "buy a Ford" to your "what Chevy should I buy?" question. I use the floor jack on the trailer, too.
