I'm using the Tsunami Aerator pumps, but they arent reversible, if you get the 800gph ones they have the 3/4" outlet so you can plumb that right into your lines. The only problem is you will need to use 2 pumps per tank. Not a big problem if you use a checkvalve where needed. The advantages to the aerators are they can run dry without the worries about melting down your impellor, like with the jabsco,s. Also aerators will be cheaper than buying Jabscos, I was going to run 3 jabscos, and now am going with 6 attwoods and it came out to be ALOT cheaper. Just as fast, if not faster.
