Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 26, 2006
Old     (grant_west)      Join Date: Jun 2005       11-13-2006, 1:14 PM Reply
After seeing Luke Duke’s alternator bracket I had to get one for myself. This simple little hyme joint and treaded rod makes for a great easy way to get proper belt tension.
Thanks for the Idea Luke.
P.S you want my old one
Old     (lukeduke95)      Join Date: May 2002       11-13-2006, 7:11 PM Reply
I'll be over tomorrow.
BRIGHT AND EARLY!!
j/k
I am glad that my idea has helped someone. Us girly men that can't adjust brackets right needed this extra help!
Old     (ifishok)      Join Date: Mar 2002       11-14-2006, 7:14 AM Reply
Where did you get this? I need one too.
Old     (grant_west)      Join Date: Jun 2005       11-14-2006, 8:56 AM Reply
Luke and I got ours at Mc Master car. Do you have a Nautique with a GT40. If so I could get the part #'s
Old     (ifishok)      Join Date: Mar 2002       11-14-2006, 9:34 AM Reply
I have a 1989 SN2001, it looks like it would work. The bar just looks like crap.
Old     (lukeduke95)      Join Date: May 2002       11-14-2006, 12:26 PM Reply
GRANT- Can you confirm this is what you ordered? These are the parts I put together from mcmastercarr on PN, but want to make sure you didnt realize something was wrong.
Alrighty folks, here is a parts list from Mcmastercarrs website.
(You only need to order the threaded shaft from them, I got the heim joints and the jam nuts in both rt and lft thread from my local Orchard for about $12 compared to the $14 each listed below)
Part Number Description Unit Price
4483T401
Ultra-Strength Ball Joint Rod End 3/8"-24 Rh Male Shank, 9544 Pound Load Capacity
$14.38 Each
4483T402
Ultra-Strength Ball Joint Rod End 3/8"-24 Lh Male Shank, 9544 Pound Load Capacity
$14.38 Each
8419K63
Easy-Adjust Threaded Connecting Rod 6" Overall Length, 3/8"-24 Threaded Female Ends
$13.46 Each
Merchandise Total $42.22
Just remember, one side need to be left hand thread and the other needs to be right hand thread in order for it to adjust.
here are some additional pics-
Old     (lukeduke95)      Join Date: May 2002       11-14-2006, 12:27 PM Reply
If the shaft was about 1-2 inches longer, you wont be on the ends of the heim joints when adjusting it.
I am gonna see if my bro can make a longer one for me since he is a machinist. They have all kinds of thread taps and such.
Old     (ifishok)      Join Date: Mar 2002       11-14-2006, 2:05 PM Reply
What's the web site address? Can't find it on google.
Old     (lukeduke95)      Join Date: May 2002       11-14-2006, 5:18 PM Reply
http://www.mcmaster.com/
Old     (ifishok)      Join Date: Mar 2002       11-15-2006, 10:03 AM Reply
Thanks for the site address. That's an awesome site, spend hours looking at stuff. I guess I should get back to work now.
Old     (grant_west)      Join Date: Jun 2005       11-15-2006, 11:01 AM Reply
Luke: I order the same threaded rod as you. The 6-inch. If I had a smaller case alternator the 6 inch threaded rod would work perfect. My alternator's case is a bit larger than your HO alternator and therefore the distance between the mounts is closer so I needed to re-order a smaller 4-inch threaded rod. You can see from the pics that the joints are almost all the way out. A 5-inch rod would have worked out best but they don’t make that length.
Old     (jwag)      Join Date: Apr 2002       11-15-2006, 11:45 AM Reply
Run down to OSH, they have all that stuff too
Old     (lukeduke95)      Join Date: May 2002       11-15-2006, 2:23 PM Reply
Jan, thats where I got all my parts except the shaft. The heim's are cheaper at OSH but only by a couple bucks.
