Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through October 15, 2006
Old     (ghostrider_2)      Join Date: Aug 2004       09-19-2006, 1:37 AM Reply
do you guys think changing a 142 thermo for a 160 will make a noticable difference in the heater? If you have done this was it worth it?
would like my heater to kick a little hotter and was told this would be great?
Old     (jayc)      Join Date: Sep 2002       09-19-2006, 4:02 AM Reply
I cahnged mine to a 160 and at the same time fitted the heater craft Y piece which improves flow at idle.
Made a huge difference and well worth it.
Old     (wakesetter101)      Join Date: Oct 2005       09-19-2006, 4:56 AM Reply
I think it would be a good idea.
Old     (ghostrider_2)      Join Date: Aug 2004       09-19-2006, 9:49 AM Reply
y piece?
Is the thermo a stock part I could pick up at an auto parts store or is it marine spec?
Old     (7890303)      Join Date: Sep 2006       09-19-2006, 9:27 PM Reply
Fuel injected engines need a correct spec thermostat, to run a proper air/fuel ratio. too cold & it runs rich all the time, which leads to early secondary ignition failure, (plugs, wires, etc).
Old     (wakesetter101)      Join Date: Oct 2005       09-20-2006, 4:54 AM Reply
Marc if its got a 142 wouldnt that make it a carb engine? EFI already has a higher thermostat.
Old     (ghostrider_2)      Join Date: Aug 2004       09-20-2006, 9:58 AM Reply
found out minedid/has come installed with a 160.
