It is also possible that something has just gotten wrapped up around the paddle wheel. The paddle wheel is fairly small, perhaps 1-1/2 inch diameter, and only the tips hang down below the bottom of the boat. Crawl under your boat while it is on the trailer and it should be easy to find. It will be off to one side of center, ahead of the prop but towards the back. Once you find it give it a spin with your fingers. It might just need cleaning out, or the little paddle wheel might need to be replaced. If the boat is out of the water the paddle wheel assembly can be easily removed from inside the boat (assuming you can get to it.)
