Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 29, 2006
Old     (roughrivermike)      Join Date: Apr 2006       08-21-2006, 5:38 AM Reply
I need some help on identifying a trick for an INT run.In the novice division you have to name your wildcard trick, so my daughter needs to know exactly what it is to get the points. Cut out HS. Then she looks like she is going to do a powerslide, but instead of a powerslide she passes the handle behind her back and spins all the way around. Is that a blind surface 180, or is it called something else?
Old     (bill)      Join Date: Feb 2001       08-21-2006, 6:11 AM Reply
if she spins toward her front foot and spins all the way around then its a surface 3,if she spins to the backfoot its a blind 180 or three depending on if she ends up switch which means shes riding the ooposite front foot when she started blind 180,or if she ends up with her front normal foot back forward then its a 360..
but terms are surface spins or surface 180s but if she holds the power slide a bit it can be called a power slide surface spin or 180..good trick for a beginner to get points IMO...
Old     (roughrivermike)      Join Date: Apr 2006       08-21-2006, 6:31 AM Reply
Thanks Bill!
