I read the above links very interesting my problem is that I am linking 2 sacs in the bow to properly install a "t" fitting and have the drain pump at an equal distance.....it would have to be at the very front of the bow, under the seat my concern is that that is not the lowest point in fact if the boat is loaded, the bow could sit higher than normal...and the water in the sacs would gravitate to the opposite ends of each sac ....will both sacs still drain properly????.
