mikeski: There are two issues regarding the proper wire size: First, and most importantant, is the ability of the wire to carry the current without overheating. This calculation does not consider the overall length of the wire. Second consideration is the voltage drop. If your battery was mounted in the bow then you could easily have a 15 foot run of wire to get to the starter, giving you a round trip distance of 30 feet. 30 feet of 1/0 wire, while carrying 195 amps, will drop 1.4 volts. That can make a big difference to the starter!
