Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 06, 2005
Old     (flyspec14)      Join Date: Apr 2005       08-30-2005, 5:39 PM Reply
I'm in the process of adding more leds & speakers to my currrent setup on my 05 Supra. THE hardest part so far is figuring out how to pull new wires. I currently have wires (power & audio) running through it, should I attach to one of those, pull it out and use that as the pulling wire and then just pull a new wire for the one I canibalize?
I'm not sure that made sense, but any input would be super helpful. THANKS!
Old     (mobv)      Join Date: Jun 2002       08-30-2005, 5:47 PM Reply
You can probably leave the existing wires in and pull new wires. Feed a fishing line in the lower opening and use a shop vac to suck the fishing line out the opening at the top of the tower. Then attach the new wires to the fishing line and pull.
Old     (mikeski)      Join Date: Aug 2003       08-30-2005, 6:17 PM Reply
Try this:
http://www.wakeworld.com/MB/Discus/messages/65921/221331.html
Old     (seattle)      Join Date: Mar 2002       08-30-2005, 6:34 PM Reply
If you don't have a snake as in the link from Mike, you can use dental floss with a little piece of tape at the end. Place the shop vac over the hole your trying to thread and tape over the hole your feeding through. I've used this method a couple of times and it works well.
