DJ, I like your dealers idea of a ground fault. sounds like your gauges--engine is searching for a better ground, this can cause surging idle, flickering dash illumination lights and a whole host of other problems. disconnect your battery and remove the ground/s from the engine and clean them with a wire brush, bright clean metal makes for good grounds. don't forget simple battery connections, if you have a ton of ground wires at the battery remove and clean them. also battery + can cause same issues. fuel injected engines work with 5vdc for sensors, so you can see even a 1 volt loss/drop and you have problems the best way to check them is with a DVOM while the boat is acting up, some simple voltage drop tests can pinpoint starting and charging / poor connections rather quickly. hope this helps, cheers
