Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through September 24, 2004
Old     (tjhooker)      Join Date: Apr 2002       08-04-2004, 10:00 AM Reply
Where did you install your antenna and run the wires. Also, I bought the Roadie external unit and I was ondering how people hooked up their roadie system to an existing stereo system.
Old    jdr            08-04-2004, 10:51 AM Reply
I have the XM Delphi unit, I believe it's similar to the roadie. Anyway, I used an FM modulator to play the XM through the existing head unit. This does work but does not give the best fidelity. As for the antenna, I put it in the bow of the boat, under the fiberglass, just below the bow light. I placed the antenna, flat side down on a piece of Dynamat, the put some silicone glue on the Dynamat and stuck it up in there. Seems to work very well.
Old     (tjhooker)      Join Date: Apr 2002       08-04-2004, 11:00 AM Reply
Jay, what type of antenna do you have for your boat?
Old    whitevlx            08-06-2004, 9:44 PM Reply
I placed mine on my dash. I slipped the wire under the lip of a cupholder.
Old     (jmanjohn)      Join Date: Nov 2001       08-07-2004, 9:38 AM Reply
Mine is under the dash, works fine.
Old     (gizel)      Join Date: Dec 2002       08-09-2004, 5:45 AM Reply
I have mine on the top of my Tower. Works great. I bought the Roof Mount one and wiretied it to one of the cross supports. I have nevr lost signal once. Not even under bridges.
Old    jdr            08-09-2004, 7:43 AM Reply
Mike, I have the little antenna that came with the Delphi unit. Small, looks like a minature mouse (computer mouse).
Old     (drewsy)      Join Date: Mar 2003       08-09-2004, 7:54 AM Reply
At first i put mine on the dash but lost the signal now and then. So i ended up putting it on top of the tower. I had to cut the wire and feed it through the tower & then resolder the connection. it works great now.
