Old     (garrikos)      Join Date: Mar 2004       06-04-2004, 12:26 AM Reply
Wich kind of propeller I need use on BayLiner Capri 1750 with Mecruiser 3.0(135 h.p.) if I want use this boat for wakeboard?
Old     (boarditup)      Join Date: Jan 2004       06-04-2004, 6:33 AM Reply
Get a Michigan Wheel or Merc 4 or 5 blade and drop down 2" in pitch. You wll have to watch your full throttle rpms so you don't over-rev.
Get a foil on your ventilation plate. That will also assist in keeping the boat on plane at 19-23 mph.
Old     (blue1439)      Join Date: Aug 2002       06-04-2004, 6:40 AM Reply
quicksilver makes a four blade aluminum prop that costs less than mercs. i just picked up one on ebay for $110 with a floating prop wrench, merc owns quicksilver so it could be the identical prop just a different name. thats what my dealer says here. its a 'quicksilver diamond 4'
Old     (garrikos)      Join Date: Mar 2004       06-04-2004, 11:42 AM Reply
BIG TNX!!!
Old     (oldirish)      Join Date: May 2004       06-05-2004, 3:03 AM Reply
I run a quicksilver 18 pitch four blade on my 18 foot Searay with the same engine. The thing pulls like a draft horse but you lose the top end. 35 mph is about max but you only need 20 - 25 mph anyhow. You will probably need to get a different trim tab or modify the one you have since the prop won't clear. Replacement tabs are about 10 bucks. I notched mine and it works just fine.
Old     (garrikos)      Join Date: Mar 2004       06-05-2004, 3:28 PM Reply
QA2184X * Diamond 4 Aluminum
4 Blade 14 1/2 Diameter X 18 Pitch $159.50 is this a good propeller for me?
1/2 Diameter-what is this?
Old     (garrikos)      Join Date: Mar 2004       06-05-2004, 3:37 PM Reply
Can some body give me link to quicksilver homepage?
Old     (garrikos)      Join Date: Mar 2004       06-05-2004, 3:44 PM Reply
To oldrish:-):
Wich diameter of propeller do u have? 14 1/2 or 15?
Old     (oldirish)      Join Date: May 2004       06-05-2004, 9:36 PM Reply
It's a 14 1/2. The main reason that I run an 18 pitch is for speed control. The Hull design of the Searay makes 20 - 22 mph hard to hold with a larger pitch. I don't know how the Bayliners are. I guess it would depend on what you're running now. Like Boarditup said, try dropping down a couple inches in pitch from what you have now and watch your RPM. As far as price, there's a guy on Ebay user name Propdoc from Medford, Oregon that sells 4 blade quicksilver props for $100 + shipping.
Old     (oldirish)      Join Date: May 2004       06-05-2004, 9:55 PM Reply
I didn't find Propdoc on ebay but I did find a Michigan wheel 14.5 x 18 for $105 from a guy in New Jersey. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2481346528&catego ry=26456
He also has a 20 pitch listed for the same price but doesn't list a shipping cost. He did list an email address for prop questions. Good Luck.
Old     (garrikos)      Join Date: Mar 2004       06-06-2004, 11:42 AM Reply
Big thanks:-)!!!!
living in Russia, and there too dificult to buy something for my boat...
With your help i'll try to buy this propeller:-)
Old     (garrikos)      Join Date: Mar 2004       06-06-2004, 11:56 AM Reply
That is my boat:-)
Old     (oldirish)      Join Date: May 2004       06-06-2004, 10:25 PM Reply
Nice boat. It looks like you take pretty good care of it. Here's a picture of mine. Same thing, just a different brand.
Old     (garrikos)      Join Date: Mar 2004       06-07-2004, 9:14 AM Reply
OOo, it's fine boat, and cool place:-)
