How the hours are put on is much more important than how many hours. If you took an engine, started it up and ran it at around 80% load and only shut it off to change the oil that engine could last a hundred thousand hours. At the other extream, take an engine, start it up once every two months during the summer and then beat the hell out of it for a few hours and that engine could be toast after 100 hours. There are a few parts of an engine that experience wear, and will enventually fail or start to cause problems. Exhaust manifolds seem to last about 500 hours. Of course, V belts, water pumps, starters, alternators, fuel pumps, etc. all have limited life and you just have to anticipate changing them. There are parts of the engine that degrade over time, especially oil seals and other rubber parts. These are going to last years. If anything, frequent use will help them out, but for the most part a ten year old engine is going to leak some oil no matter how many hours of use it has. There is some amount of degredation due to sitting, and the longer it sits in one stretch the worse it can be. The cylinder walls can form a layer of rust when the engine is just sitting. This rust can cause pitting of the cylinder walls, which will eventually lead to early ring failure and can cause excessive amount of "blow by" and oil consumption. An engine that is run every day will not have this problem. An engine that sits all winter will. A boat that has 75 to 150 hours a year on it and has been treated well could easily be in better shape than a boat that has only 20 hours of use per year on it. I would recommend avoiding the extreams. In fact, I wish that I had followed my own advice. I just bought a houseboat with twin outboards. The motors were only two years old and had only 16 hours on them. Well, after 9 more hours I have the boat in the repair yard and am waiting on having the carburetors on both motors replaced. Seems that the gas sitting in the carbs for so long managed to destroy them. Rod McInnis
