If you hear a slight hum but not the normal noise you would from your pump I would check the impellor. I've had a couple where the impellor looked fine but it was stripped on the portion that connects to the pump. I'm talking about the "keyed" portion of the impellor, you need to pull the piece and look at the back side, the black portion if you are running the yellow impellors.
