Old     (ladythump)      Join Date: Jul 2004       06-03-2005, 7:23 AM Reply
I kept the two main battery cables that connected to the main battery of the boat on the main battery. I run a positive off that battery to a post on the relay. I run a positive off the stereo battery to a post on the relay. I have a negative cable from one battery to the second battery. And one wire from the ignition switch to the relay......
Do I need to have one wire come off the alternator to the relay?
Old    josh_tn            06-03-2005, 7:28 AM Reply
Nope, the alternator will be connected to your main battery which is already connected to the relay since you left the main cables the way they were. Sounds like you're all good to go.
Do you also have a ground wire run from the small post of the relay to one of the battery ground posts?
Old     (ladythump)      Join Date: Jul 2004       06-03-2005, 8:07 AM Reply
yes i have the ground wire from the relay to the ground post on a battery. forgot about that part.
Okay i was just making sure I had it hooked up correctly.
