Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 03, 2009
Old     (andrewjet)      Join Date: Jan 2003       05-27-2009, 5:35 PM Reply
Whats the big deal about the Tsunami pump. I have the Rule 1100's which flow 1100 gpm. The tsunami doesn't even show there flow rate but say that It flows double than any other pump? Is this bullshirt or what? Great marketing? I just bought the Flying High Pro 750 and boy are they pushing this pump. Whats your take on it? Thanks Jet
Old     (bremsen)      Join Date: Aug 2005       05-27-2009, 6:10 PM Reply
Been using the 1200s for 3 seasons on fly high v-drive sacs. No problems with the pumps and they'll fill/drain 400+lbs in a little over 4 min. Never used the rules just b/c they were always way more expensive.
Old     (wakesurfer08)      Join Date: Sep 2008       05-27-2009, 6:47 PM Reply
We use both, the Rule 1100's are hard plumbed into 750's,and the Tsunami 1200 just to fill a walk way 400lb and I see no real difference. We are also using the factory Malibu ballast pumps (Piranha I believe)to fill the integrated front bag and I see no difference with that pump vs the other pumps which are larger and I can get the Malibu pumps a lot cheaper also. Just My input,hope this helps you.
Old     (andrewjet)      Join Date: Jan 2003       05-27-2009, 7:27 PM Reply
Oohh! So the Tsunami's are 1200 gpm? Why don't they just say that? And Ryan..I pick up the Rules at the fishing shop for $39 bucks. Way less than the $99 they wanted for the Tsunami. OK..so no real difference?
Old     (ryker1)      Join Date: Oct 2008       05-27-2009, 9:03 PM Reply
the $99 is for the cigarette lighter pump with hose and attachments. otherwise its $40
Old    thebiggmann            05-27-2009, 9:16 PM Reply
I just bought the attwood tsunami pump (which is the same that flyhigh uses from what i can tell), two hose clamps, 3 feet or so of hose, a brass hose attachment, and a water bed fill kit. Cost me like 50 bucks to make the same pump they sell for 100. Works great.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-28-2009, 7:50 AM Reply
yea 1200 gph is what they're rated for. got 4 rule 1100 in my boat with no issues.
Old     (showmedonttellme)      Join Date: Mar 2008       05-28-2009, 8:08 AM Reply
The Tsunami runs the Rules out of the park. Maybe its the bigger diameter hose, but it beats my Rule 2000 on a 400lb sack by at least a minute. Hands down fastest pump out there.
Old     (wakeviolater)      Join Date: Sep 2004       05-28-2009, 8:22 AM Reply
corby speaks the truth.
Old     (andrewjet)      Join Date: Jan 2003       05-28-2009, 9:43 AM Reply
Hey Nacho. Are they mounted horizontal?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-28-2009, 9:48 AM Reply
They are horizantal. I've got the fill pumps and their manifold on a scoop to force-feed them a little to get started.
Old     (andrewjet)      Join Date: Jan 2003       05-28-2009, 9:56 AM Reply
Nacho..can you send me some pics? andrewjetmitchell@sbcglobal.net
Old     (bmartin)      Join Date: Jan 2007       05-28-2009, 10:08 AM Reply
You can get hardware-less Tsunami's for $42. I suspect if all the the hardware was equivalent, there would not be much difference in a Rule 1100 or Tsunami 1200 GPH pump. Plumbing diameter makes a huge difference as does the height you are raising the water.
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_52431____SearchResults?ordProd=Y&CMID=TOP_ selectitems#itemDetail
