Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 13, 2007
Old     (zacharoo)      Join Date: Nov 2005       02-24-2007, 7:08 PM Reply
Is 2 channels of my 6ch JL amp at 75 per channel enough power to make my new Fusions T series w/LED sound good. I know more power is better with the gain turned down but have I got reasonable power being supplied. I don't want to blast the rider, I want a reasonable balance between inside and out. Can a gain knob be use in my current equipment set up. My head unit is a Kenwuss 5028. I would like to run the bow speakers off the hu power because I want to not buy another amp if I can get away without it. The four other speakers are polk DB 675 currently all six are the amp. But again I want to remove and use two channels to power the new tower speakers. Can this work? Mikeski any thoughts?
Old    walt            02-24-2007, 8:16 PM Reply
I'm not a expert but I'm running a 300 JL on my Fusions. I would guess that 75 would be under powering them.
Old     (joe_crawley)      Join Date: Jan 2007       02-24-2007, 8:25 PM Reply
Tower speakers should be run in mono, so you'll be running them bridged. Looks like that amp pushes 140RMS when bridged into 8 ohms, and you really should look for more power. I'd buy a crappy amp off ebay that pushes 500RMS bridged into 2 ohms (more importantly look for something with at least a 50A fuse, not any specific output power rating) and you're good to go. You certainly don't need a nice sq amp to run tower speakers, if you spend over $200 for this amp you've spent to much.
Old     (05mobiuslsv)      Join Date: Apr 2006       02-24-2007, 8:44 PM Reply
Not to many cheap amps on Ebay that you can bridge to 2 ohms. Most amps are only good to 4 ohms bridged. Better off going with a high powered amp (750+ watts) running the tower speakers in series at 8 ohms bridged giving you clean cool power from the amp.
Old     (joe_crawley)      Join Date: Jan 2007       02-24-2007, 8:57 PM Reply
Plenty of mono amps though that you can run at 2 ohms (stay away from D class amps though)
Old     (05mobiuslsv)      Join Date: Apr 2006       02-24-2007, 9:04 PM Reply
Show me some, post some links I'd like to check those out for my setup.
Old     (joe_crawley)      Join Date: Jan 2007       02-24-2007, 9:47 PM Reply
Here is one for $90, I can list some more.
This one has a 60A fuse, so it will give you more than you need. Only problem is there is no high pass filter, but it sounds like he'll be using a output from that JL amp which will take care of the high pass.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120090401147
Old     (05mobiuslsv)      Join Date: Apr 2006       02-24-2007, 9:55 PM Reply
Joe how can you use that amp to power tower speakers with a full range signal. I have just never heard of that before, and that amp has a built in low pass that scrubs out the high pass signal correct?
Old     (joe_crawley)      Join Date: Jan 2007       02-24-2007, 10:01 PM Reply
It does have a built in low pass filter, but it is enabled with a sliding switch. It acts just like a regular class AB amp when the low pass is off
Old     (05mobiuslsv)      Join Date: Apr 2006       02-24-2007, 10:04 PM Reply
So you can turn it to "off". So what's the deal with the class D amps, are you able to do this with these as well?
Old     (joe_crawley)      Join Date: Jan 2007       02-24-2007, 10:17 PM Reply
You could probably do the same thing with a class D mono, but nobody has been able to make a class D with low enough switching distortion for full range amplification. The distortion isn't especially obvious below 100Hz so class D works well for subs, but not for a full range speaker.
By the way, I agree with you that he would be better off with a two channel amp run at 8 ohms because it is so simple to add 2 more speakers at that point
Old     (chas)      Join Date: Feb 2002       02-24-2007, 11:08 PM Reply
AP1000M-1000W MONO Subwoofer Amplifier
Old     (05mobiuslsv)      Join Date: Apr 2006       02-25-2007, 9:38 AM Reply
I noticed that too.
Old     (zacharoo)      Join Date: Nov 2005       02-25-2007, 10:45 AM Reply
Is there a preferred wiring kit or harness that good better, best for the fusions?
