I was being quite sarcastic really when asking about running better with 91. It's true about knocking ART but the loss of power, at least on this engine would come from the computer pulling timing out due to Pre-Detonation (knock). Apples and Oranges and both are caused by using gasoline with to low of an octane percentage. More so that WOT testing, I find that if performance suffers when the air temp/density changes (cold and crisp in winter to hot and humid during summer) you tend to know you are using too low of an octane gas. This is especially exaggerated in our boats since they use typically closed loop systems that go off pre-programed tables instead of a more efficient "Mass Air" system as you see in automobiles today. It's just ignorant to make a blanket claim that your engine runs better with 91, especially when in reference specifically to a low compression big block that rarely sees the bright side of 5k RPM. Besides in Texas it's 87, 89, or 93. Minimal difference between 87 and 89, and I certainly don't need 93.
