Need advice. We are having problems with the rode sling shotting back into the boat. I took a hit to the hand and ribs which are prttey bruised. We have him on a 75 foot line and same results if it is hooked to the tower or the piline. Advice?
Are you using poly-p or poly-E line? I've never heard of spectra wakeboard line doing that. You can buy a recoil tube designed to prevent slalom handles from snapping back in the boat and knocking out the driver. They work pretty well. Cost about $20, I think.
Check out the Accurate lines. http://www.accuratelines.com/default2.asp What happens is the rider loads the line up with his/hers weight and the bungy ski rope slings in the boat. This happens all the time with sking.
I went and bought a proper wakeboard rope (yellow jacket) after hearing all the benefits of them. This was one benefit I had not heard of but am the most happy with. It is worth the extra bucks for the safety aspect alone.
I use Spectra (Yellowjacket) and even with it loaded up, the most it has ever shot back is about 10 feet. Well worth the money, especially on riding performance, etc.
