The higher signal has nothing to do with over-working an amp, it keeps the signal to noise ratio better. EQ's are generally used to compensate for system responses that are less than ideal. If used properly they can be great, if misused they can result in a very weird sounding system. Also, if it is an analog EQ it will add phase changes to the signal.
